TwinTurbo.NET: Nissan 300ZX forum - Could the TPS voltage readings cause the engine to die?
KevinsFairlady
on November 03, 2020 at 11:05 AM
make sure the TPS shaft is machined correctly
posted by vorpalZed
on November 02, 2020 at 11:21 AM
I have the original Rob's throttle bodies and have an issue where the engine will occasionally drop the RPMs so low during deceleration that the engine cuts off. Wondering if this might be a cause...
PSA: RobZ Billet Aluminum 62mm Upgraded Throttle Body Set
MJzTTZ
10:05:24 11/02/20
Which FB group? (n/m)
ConVerTT
10:08:25 11/02/20
Re: Which FB group?
MJzTTZ
10:15:25 11/02/20
Re: Which FB group?
MJzTTZ
10:22:05 11/02/20
Re: PSA: RobZ Billet Aluminum 62mm Upgraded Throttle Body Set
MJzTTZ
10:24:53 11/02/20
vorpalZed
11:21:57 11/02/20
^ This! (n/m)
MixManMash
12:25:11 11/02/20
Re: make sure the TPS shaft is machined correctly
OleMissFan
13:51:45 11/02/20
I have this issue as well, drivability has been poor
komplexZTT
15:39:32 11/02/20
Mine do not have this issue. Different run maybe? (n/m)
ConVerTT
17:45:10 11/02/20
I fixed the problem with the shaft
AndrewG
06:34:06 11/03/20
Excellent! (n/m)
ConVerTT
08:43:48 11/03/20
I removed my tape and did this instead
komplexZTT
10:19:06 11/04/20
Same here re the TPS and spacing washers (n/m)
AndrewG
11:31:10 11/04/20
Could the TPS voltage readings cause the engine to die? -
KevinsFairlady
11:05:52 11/03/20
Whats the consensus on these are they worth?
JerseyTex
12:49:46 11/02/20
MJzTTZ
15:13:10 11/02/20
I already sent him an email (n/m)
Dallas DamonZ
16:06:49 11/02/20
Would be nice if someone could post a before/after dyno...
Stanky (BC)
17:47:56 11/02/20
I doubt you'll see any difference on a dyno. (n/m)
MixManMash
21:46:05 11/02/20
I've been running mine since ~2012 IIRC -I'm happy with them
BoneZ (MD)
19:54:58 11/02/20
Re: I've been running mine since ~2012 IIRC -I'm happy with them
MJzTTZ
20:02:02 11/02/20
I didn't do a comparison- built the car altogether
BoneZ (MD)
18:09:39 11/03/20
DanielThomas
00:24:39 11/04/20
What does it take to replace those seals?
ZXoltan
07:10:36 11/04/20
It's been a while, but if I recall correctly
BoneZ (MD)
20:03:40 11/04/20
Is there a link to the group buy anywhere? I cant find it
Mr.Stacy
10:57:21 11/06/20
Re: Is there a link to the group buy anywhere? I cant find it
Zeus
18:21:55 11/06/20
Thanks (n/m)
Mr.Stacy
16:12:01 11/07/20
